Slow internet
davegee59
Slow internet
Why is my internet so slow if it's running around at 36 if I connect my laptop or iPad to my iPhone by personal hotspot its miles faster am I being ripped off or is there a simple explnation
atb
Dave
3 REPLIES 3
MrSilver
Fixes: 9
Re: Slow internet
Hi Dave,
You haven't really given much to go on here... can you be more specific?
Do you mean you should be getting 36mb but aren't, but if you connect to a personal hotspot (4g or something?) its faster?
How are you accessing the internet, over wifi? Have you tried via a direct cable to the router etc?
Has it always been slow or just started?
What are you using to measure speed too?
thx ms
davegee59
Re: Slow internet
Hi thanks for the reply to my thread I was  little vague I meant my service is running at 36 mb but it is still slow whilst browsing and I connect wirelessly
I use the bt wholesale speed test nod it returns 30 plus all the time
atb
Dave
MrSilver
Fixes: 9
Re: Slow internet
If you can its best to test with a lan cable, with the router plugged into the master socket, although i the BTW test gives you 30 on a 36meg line they are probably not causing you issues.
If it is intermittent then it may be noise on the line, or it may be effected by your PC, its ifs doing lots of updates etc.
One thing some people find works is to change the ir DNS settings to use google on 8.8.8. (dont have the link but if you search 8.8.8.8 on the forums it should give a guide to changing DNS settings!)
What speed do you get if you go to speedtest.net ?
thx ms
