Slow internet speeds in the evening but not in the morning Test Results
Strat
Fixes: 565
Re: Slow speeds in the evening part deux
Moderator's note by Dick (Strat): Topics merged for clarity.
dws1900
The ticket was raised to find a solution to the reoccurring slow throughput, as measured by speed-tests during the period 18:00-00:00 (typically, it can start earlier or slightly later)
After a call from PN, on the 13-Mar-2019,  that evening, and every evening subsequently the throughput has been the same as measured from 00:00-18:00
PN have informed me that there are no issues with the s-VLAN, dslam or backhaul.
GEA tests are good, with some showing crosstalk.
A L&S was not carried out on the 13th as there was no disruption to the circuit.
LAN traffic was at a minimum.
PN can offer no reason for why this should occur.
I therefore ask the community for comments.
