Slow for fibre extra?
I've been on Plusnet Fibre Extra for a few days now.
I'm getting speeds of
Down : 36.67
Up : 12.49
I'm plugged into the router via the Ethernet cable and there is no other devices on the network.
Should I be getting faster speeds that this?
My minimum Guaranteed Access Line Speed is 54Mb Downloading
Thanks,
Martin
7 REPLIES 7
Fixes: 964
Re: Slow for fibre extra?
Hi Martin,
Whilst I've replied to your post over here it looks from this post you're getting less than expected.
Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection. Please ensure that no other devices are connected to the router (wired or wireless), and there are no open background tasks on the PC you're using.
Once you have the result, please complete the further diagnostics. This will store the result on the supplier system.
Cheers,
Anoush
Hi Anoush
I'm afraid it's gotten worse.
34.76 Down
0.97 Up
Could it just be the fact that it's early days with fibre?
Thanks,
Martin
Fixes: 964
Given that your line speed is in sync at 60mbps, I'd expect higher than 36mbps 34mbps.
Can you complete the further diagnostics for us? Also, do you experience the same problems using a different device?
Anoush
I get the same speeds on my phone via wifi.
the second diagnostics result is attached.
Fixes: 964
Thanks for that, I'd recommend reporting this to us at http://faults.plus.net
Anoush
Thank you Anoush,
I've reported it to faults.
Cheers, Martin.
Fixes: 964
Thank Martin,
Our faults team will pick that up next week.
Anoush
