Slow for fibre extra?
- Slow for fibre extra?
12-08-2017 1:33 PM
I've been on Plusnet Fibre Extra for a few days now.
I'm getting speeds of
Down : 36.67
Up : 12.49
I'm plugged into the router via the Ethernet cable and there is no other devices on the network.
Should I be getting faster speeds that this?
My minimum Guaranteed Access Line Speed is 54Mb Downloading
Thanks,
Martin
Re: Slow for fibre extra?
12-08-2017 4:01 PM
Hi Martin,
Whilst I've replied to your post over here it looks from this post you're getting less than expected.
Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection. Please ensure that no other devices are connected to the router (wired or wireless), and there are no open background tasks on the PC you're using.
Once you have the result, please complete the further diagnostics. This will store the result on the supplier system.
Cheers,
Anoush
12-08-2017 4:27 PM
Hi Anoush
I'm afraid it's gotten worse.
34.76 Down
0.97 Up
Could it just be the fact that it's early days with fibre?
Thanks,
Martin
12-08-2017 4:51 PM - edited 12-08-2017 4:52 PM
Given that your line speed is in sync at 60mbps, I'd expect higher than 36mbps 34mbps.
Can you complete the further diagnostics for us? Also, do you experience the same problems using a different device?
Anoush
12-08-2017 5:06 PM
I get the same speeds on my phone via wifi.
the second diagnostics result is attached.
12-08-2017 5:16 PM
13-08-2017 9:43 AM
Thank you Anoush,
I've reported it to faults.
Cheers, Martin.
13-08-2017 10:00 AM
