Slow fibre
rickesh10
Slow fibre
Today my fibre bb is really playing up.  Its been slow on and off but i've seen a considerable decrease today.  Results from speedtest are:
Can anyone shed any light on why this might be?  I should be getting somewhere near the 38mbps but I understand those speeds are estimates.
I am on a wired connection with the original equipment.
Many thanks,
Rickesh
13 REPLIES 13
MattyC
Fixes: 46
Re: Slow fibre
Hi rickesh10,
Unfortunately, it's looking like a phone fault. I've raised this to our suppliers (the text was from me), and we suspect it to be resolved by 20/07/2015.
Let me know how you get on.
Matty
rickesh10
Re: Slow fibre
Hi Matty,
Thanks for the update!  Its really appreciated and i'm glad you guys are looking into it Smiley
Kindest Regards,
Rickesh
MattyC
Fixes: 46
Re: Slow fibre
No worries Smiley Apologies it's bad news.
Matty
rickesh10
Re: Slow fibre
I'm just glad there's a reason Smiley
rickesh10
Re: Slow fibre
I just wanted to give an update and say how appalled I am with the level of service I have been given by plusnet.
So, after the issue with my telephone line was resolved, I found that my internet connection was dead.  Rang plusnet and told them. Was advised that it was raised and that it should be resolved in the next 3 days.  Then I got a call on the 3rd day to say my internet was down (which I already knew) and that an engineer had to come out.  Engineer comes out and says there is a fault with my fibre port in the cabinet and that should be fixed in the next day.  Ring up plusnet and get advised that they will chase BT Openreach and give an update in 72 hours.  I then get a text and not even a courtesy phone call to say that some new ports will be installed into the cabinet and i'd get an update on the 31st of July.  I've been without a connection for a week and possibly without one for two weeks.
I honestly cannot believe this is how you treat your customers.
rickesh10
Re: Slow fibre
So its been over a month now and i'm still without an internet connection.  An engineer was meant to come out yesterday to fix the cable tie but who knows if that actually happened!  I was meant to get an update from the faults division and from the customer services department but that didn't happen.
I just can't believe how useless Plusnet have been in this.  No updates until I chase them and then I get fobbed off by saying it will be escalated which means absolutely nothing.
I wanted to post here to highlight how badly you treat your customers.
This post will most likely be ignored by any plusnet moderators...
Strat
Fixes: 565
Re: Slow fibre
Quote from: rickesh10
As we are simply customers we cannot influence the outcome of your issue.
Terranova667
Fixes: 5
Re: Slow fibre
Strat i'm thinking the OP is referring to the CRT rather than Mods such as your good self, that said the CRT have been very quiet around these parts you use to see them on a daily basis now it's pot luck if one shows up what's happened to them all  ???.
Mayfly
All Star
Re: Slow fibre
Some of the team have all been on this afternoon but I have noticed [because it's happened to me] that posts for whatever reason do appear to get over looked by the digi care team or whatever they are called these days.
Overworked perhaps?
rickesh10
Re: Slow fibre
Hi, sorry I didn't mean the moderators but the Plusnet care team.
After me speaking to Plusnet again it transpires that BT had put the call in the wrong queue and its now been correctly assigned for the 21st of this month.
TBH, i'm not sure who to believe anymore.  I can't see why this has taken 5 weeks for an engineer to go out and it just seems like Plusnet do not care.
Lets see what happens on Friday...
MatthewWheeler
Fixes: 479
Re: Slow fibre
Sorry to hear it's still down.
Leave it with me.
 Matthew Wheeler
rickesh10
Re: Slow fibre
Thank you Matthew
MatthewWheeler
Fixes: 479
Re: Slow fibre
I've made one of our Faults agents aware and you should have a update soon.
 Matthew Wheeler
