Slow fibre tonight?
carlmagic
Slow fibre tonight?
My account says i'm connected at 78Mb/s and my modem is showing i am connected at 80/20. Its not just the speedtest which is slow, twitch is slow and downloading from steam also.
Wondering if you can shine any light to whats going on? Thanks
comicbbokguy
Re: Slow fibre tonight?
Mine slowed down around 8pm.
Just login to router and disconnect and reconnect and it goes back to full speed.
Could be something to do with what happened around 8pm:
carlmagic
tried disconnecting and reconnecting and nothing still the same
on http://usertools.plus.net/@gateway/
it says i am connected to ptw-bng02
Terranova667
the BNG gateways are always having issues i don't bother with them I haven't been able to stay on one for very long before it just drops the session so every time I land on one i just gateway hop until i'm on something other than a BNG one, I'm currently on pcl-ag08 and haven't had any issues with it including today nothing that was noticeable.
carlmagic
How do I gateway hop? Is it possible for plusnet to assign me to one manually? Thanks
Not they are not!  Sad I'm connected to pcl-bng03 & it's as steady as a rock. Prior to that I was permanently connected to pcl-bng01 for over 2 months. Smiley
Just log into your router & manually disconnect. It will then reconnect automatically after about 60 seconds & you should have changed gateway. You may have to do it a couple of times.
rongtw
Fixes: 12
Any BNG gateways have terrible connections for Gaming !
Fixes: 161
Hi there.
Sorry to hear you've had problems. Is everything working okay now or are you still having issues?
 Matthew Wheeler
carlmagic
Hi Matthew it seemed to speed up again after midnight. Which seems like it might have been gateway congestion? I have done some gateway hopping as above and have moved to ptw-bng01 rather than ptw-bng02. Ill get back to you tonight in the "prime time" to see if it stays or if it drops again. Thanks Smiley
Would like to ask Matthew is what the others above said about gaming and the BNG gateways true? If so is it possible to manually assign someone to one of the other ones? Thanks.
thesawdust
Quote from: tijara33
I was connected to pcl-bng01 for nearly 60 odd days, seems pretty stable. Then for some reason my line kicked the bucket and spat dummy out and now applied interleaving.
I still prefer PTN gateways. Low latency  Cool
Fixes: 161
There might have been a issue last night however I'll leave that up to the Network guys to investigate.
We aren't able to force customers onto specific gateways and in all fairness being a gamer myself I've never seen any issues with the BNG's.
Do let us know if you have issues again.
 Matthew Wheeler
rongtw
Fixes: 12
@Matthew Wheeler  i dont know what it is but BNG are always bad for BF4  Undecided
carlmagic
seems to be starting to slow down again Sad normally get 74/18 ish on a speedtest with 12ms ping.
Did a gateway jump, now on ptn-bng02 from ptw-bng01
No better, infact worse?
You are currently connected to gateway pcl-bng03
<a href="http://www.speedtest.net/my-result/3982454634"><img src="http://www.speedtest.net/result/3982454634.png" /></a>
Seems very strange getting simmilar results on 3 different gateways? Modem still synced at 80/20 and plusnet showing line speed of 78mbps
gateway pcl-bng01
gateway ptw-ag02
gateway ptn-ag01
gateway ptn-ag01 seems to be the fastest out of all the ones i have gotten above. But its still 20mbit or more off what i am paying for.
jamesanstee
Im currently on gateway ptn-ag01 and not seeing any speed issues
http://www.speedtest.net/result/3982730110.png
carlmagic
I have raised the ticket number #96187230 if a plusnet staff could check it out that would be appreciated.
Hi thanks for checking james.
It seems mine just keeps going slower and slower
Still connected to the same gateway as you and my modem stats are the same
Them errors are with a 22 Hour uptime.
Im guessing it must be something between my cabinet and the gateway then? Would i be best raising a support ticket?
Also started a think broadband ping tracker results here;
this looks awfull to what it was when i first got fibre installed just over a month ago. Please be aware though that the compleate drop outs where me trying to get the TAP3 test working. My connection doesnt go down fully. Just slows down!
Also tried performing a TAP3 Test however it just errors and doesnt show me the results as shown:
Early morning around 6am for comparison
