Slow fibre speeds
- Slow fibre speeds
Slow fibre speeds
18-03-2021 8:54 PM
Here is what I should be getting.
Your broadband service
Product: Unlimited Fibre Extra
Estimated Download Range: 54 - 72Mbps
Estimated Upload Range: 16 - 18Mbps
Minimum Guaranteed Speed: 49.6Mbps
Current Line Speed (Download): 78Mbps
Is there anything anyone can do it maybe help with the issue please.
Re: Slow fibre speeds
20-03-2021 12:51 AM
Can anyone who works for Plusnet look at this for me please? if I reboot my hub I will get around 60mps but within 24 hours im back down to 15-25mps.
20-03-2021 4:30 PM
I am in same boat they keep saying it fine but it isn’t
21-03-2021 10:04 PM
its happens everytime,just checked my speeds at its around 25mbps should be 60-70. I thought there were advisers on here who could help by doing a check or something.
21-03-2021 10:11 PM
Just rebooted my router now my speed is 58mbps. anyone else suffer from this problem?
22-03-2021 8:33 AM
Hi @Jbutton,
I'm sorry to hear that you are having problems with the speed of your broadband. Thank you for letting us know that the speed improves when you reboot your router but then drops again within 24 hours.
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
24-03-2021 10:10 AM
We've had this off and on the years we've been with Plusnet. Currently in an On period where this is happening over and over, normally at times you really need it. Good luck trying to have a Zoom call (the sort of ones you were able to have two weeks ago when it was all stable). No one can ever seem to say what the problem is - well rather that there's no problem. Openreach have been out and the physical line is fine which we suspected was probably the case. The one time it stays static seems to be around contract renewal time so we've stupidly renewed every time assuming a fix was in only for it to start off only a few months later again.
24-03-2021 10:41 AM
24-03-2021 11:56 AM
Still Plusnet rooky. However we now have a massive calendar note to remind us not to renew and try elsewhere come the next renewal!
24-03-2021 1:28 PM
If it continues I will have to ring up and see what they say, I don’t hold any hope of it being sorted though.
