Slow fibre speeds since swtiching
- Slow fibre speeds since swtiching
30-03-2019 12:29 PM
I switched to Plusnet Fibre back in January and have had problems ever since with my speeds.
I've had engineers out but no change.
I was since told that their were issues with my port at the box on the street and they would be fixing it. I was also sent a new router to see if that was the issue. This was a few weeks ago but still my speeds are rubbish (worse than non-fibre previously!) Latest speed test below!!
I'm still being charged (and paying) for guaranteed speeds of 34mbps - what does this guarantee mean as no-one seems to be trying to sort out the issue!
Help!!!!!!!!!!
Speed test
Re: Slow fibre speeds since swtiching
30-03-2019 1:30 PM
I believe that the guarantee means that if the guaranteed speed cannot be attained 30 days after reporting it then you can cancel your contract without penalties such as cancellation charges.
30-03-2019 3:35 PM
I've tried to test your circuit again today to see what is happening in real time - but our suppliers tests results are not available as the initial fault was still open on their side.
I have asked then to close this so we can retest. This can take up to 24hrs to fully complete.
I'll check on this later in the evening and if results are provided I'll update this thread, if it's still pending a close, then I'll update this thread tomorrow.
Apologies for the inconvenience, but I'll keep you posted and give you the results as soon as possible.
Kind Regards,
MoR
30-03-2019 5:04 PM
Cheers MoR - I'll await your update. Hopefully something will get sorted soon!
30-03-2019 5:14 PM
No worries @jonathanlayton - i'll check on this in an hour or so and update you on here with the results or let you know it will be tomorrow.
Thanks for the understanding and patience you are showing.
Kind Regards,
MoR
31-03-2019 10:40 AM
Just a quick update to let you know that the speed results for your line are still unavailable, however, I have been able to re-raise this back to our suppliers for investigation. I'll keep an eye on this throughout the day and let you know when they come back with further info.
Best wishes
Dave
03-04-2019 7:25 PM
Hi. Any updates for me as I'm still waiting?
03-04-2019 8:32 PM
Apologies for the delayed response.
Our tests are showing a potential external fault but we'll need you to raise a fault here so we can investigate further.
If you can post back once you've done so we'll get that picked up for you
03-04-2019 9:19 PM
I keep being told that I have an external fault with my fibre port but nothing seems to get done about it! There should therefore already be an open fault registered as It's never been resolved. I started to complete the fault form via your link but haven't got the time to complete all the checks again tonight. I'll have to start again at the weekend when I next have chance! Feel like I'm just going round in circles!!!!
04-04-2019 10:46 AM - edited 04-04-2019 10:49 AM
Hi @jonathanlayton, I'm sorry to hear you're having speed issues. Apologies it feels like you're making no progress with this issue however I'm hoping to get this progressed for you. The previous fault you had open regarding a port issue and awaiting on a LUMMS case to complete did so and looked to resolve the previous speed issue you were having . The speed issues you're currently seeing however don't look at the time to be related to the previous port issue you had and I can see the current fault raised with our suppliers is advising we get a engineer out to investigate further.
As the issue we are detecting as seen below could be either internal or external we would advise a few troubleshoot steps to do your side to rule a few internal factors out before we look to book an engineer appointment.
Test Outcome | Fail | |
Test Outcome Code | GTC_FTTC_SERVICE_1613 | |
Description | Potential HR Joint detected on GEA service. Please continue to submit a trouble report | |
Main Fault Location | CE | |
Sync Status | In Sync | |
Downstream Speed | 27.6 Mbps | |
Upstream Speed | 1.2 Mbps | |
Appointment Required | Y | |
Fault Target Fix Time | ||
Fault Report Advised | Y | |
Estimated Line Length In Metres | 655.0 | |
Upstream Rate Assessment | Low | |
Downstream Rate Assessment | Low | |
Interference Pattern | Not Detected | |
Service Impact | No Impact Observed | |
Home Wiring Problem | Not Detected | |
Downstream Policing Discard Rate | 0.0 | |
Customer Traffic Level | Upstream and Downstream Traffic Detected | |
Technology | VDSL | |
NTE Power Status | PowerOn | |
Voice Line Test Result | Pass | |
Bridge Tap | Not Detected | |
Radio Frequency Ingress | ||
Repetitive Electrical Impulse Noise | Not Detected | |
Cross Talk | ||
Profile Name | 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Retransmission Low | |
Time Stamp | 2019-03-21T20:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 27.5 Mbps | 27.7 Mbps | 27.6 Mbps |
Up Stream Line Rate | 1.1 Mbps | 2.0 Mbps | 1.6 Mbps |
Up Time | 749.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 16.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-04-03T19:10:36Z | 2019-04-03T19:25:36Z |
Ingress Code Violation | 1 | 1 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I'd recommend starting with basic checks here:http://goo.gl/p2tpvL
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the speed issues stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
By all means if the issue persists after going through the troubleshoot steps and when in the test socket then if you could please udate the ticket I've left on your account here with the required information we'd be happy to progress this further. Please also drop us a message on here whether you reply or if the steps look to improve the speeds.
