Slow fibre speed
Shaz2k11
Slow fibre speed
Since i got fibre a year ago i have only been getting half the speed i should nothing fixes it not even 3 openreach visits just want to know what my options are as i am not paying for half the speed i should be getting
1 REPLY
Fixes: 508
Re: Slow fibre speed
Sorry to hear you're having speed issues
Since your speeds remain below your estimates I'd recommend getting this reported to us as a fault again so we can raise this back to our suppliers for further investigation. You can raise a fault at http://faults.plus.net
Apologies for the inconvenience caused.
Anoush
