Slow fibre download Speeds
FIXED- Subscribe to RSS Feed
- Slow fibre download Speeds
24-10-2018 12:02 AM
I've been noticing for the past few days, dramatically slower download speeds. Buffering on Youtube Videos and even interlaced images on Autotrader etc when loading (like its back in the 90's!). I ran tests at both Speedtest.net and on the BT Wholesale Test (at 11:30pm at night). They are reporting around 5MB download an 9MB upload. When I try to run the advanced test again I get a message saying the Tap1 test was not conclusive and to raise with my service provider.
Fixed! Go to the fix.
Re: Slow fibre download Speeds
24-10-2018 12:10 PM - edited 24-10-2018 12:12 PM
Hi @RichJ,
I'm sorry that your download speed has dropped and for any inconvenience that this is causing you. I've tested your line but the test hasn't picked up the cause of the issue from here and indicates that your line is currently syncing at 63.6mbps, which is towards the top end of your line's estimated speed of 44-65mbps. For reference, today's test result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 63.6 Mbps | ||||
Upstream Speed | 13.4 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 635.1 | ||||
Upstream Rate Assessment | Reasonable | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-10-11T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 63.6 Mbps | 65.6 Mbps | 64.4 Mbps |
Up Stream Line Rate | 13.2 Mbps | 13.4 Mbps | 13.3 Mbps |
Up Time | 868.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-10-24T10:46:04Z | 2018-10-24T11:01:04Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please can you confirm whether this issue is solely affecting wireless connections or if it's affecting wired connections too?
Please can you run through our troubleshooting guides here and let us know how you get on. If the troubleshooting checks don't resolve the issue, please report it here and let us know when you've completed it.
24-10-2018 10:03 PM - edited 24-10-2018 10:04 PM
Solved... sort of!
So I ran Speedtest App on iPhone (through wifi) and on a Wifi Laptop, both returned 59+ Mbps download.
Seemed to be only my main desktop PC (on a wired connection)
So I rebooted router again - didn't seem to do anything.
Updated Ethernet Drivers - No change but I noticed that the Local Area Connection speed was set at 10 Mbps.
I then switched out the Network Cable and the LAN Speed upped to 100 Mbps.
I then put back the original network cable and LAN Speed jumped to 1.0Gbs
I'm now getting 59+ MBs download and 12.5MBs upload.
I don't know why the setting had changed? - Maybe faulty network cable? Anyway, working again now.
Many Thanks!
25-10-2018 10:59 AM
