Slow fibre broadband.
pittdj70
I query a noise margin of 10dB and a slower than expected download rate. Is there enough here to warrant raising (another) fault? Once upon a time this line was good to fully utilise the 38Mb/s service and was very stable, but not now.
PlusNet profile.
Phone exchange:
BRENTWOOD
Estimated line speed:
49Mb (This may vary between 35Mb and 49.6Mb) - Checked on 2017-07-24 22:11:22
Current line speed:
27.6 Mb
Router PlusNet Hub One.
DSL uptime:1 days, 01:25:36
6. Data rate:5715 / 28682
7. Maximum data rate:6558 / 38411
8. Noise margin:6.0 / 10.0
9. Line attenuation:32.0 / 21.6
10. Signal attenuation:34.1 / 19.3
BT Speedtest.
1. Best Effort Test: -provides background information.
Download speed achieved during the test was - 19.41 Mbps
Additional Information:
IP Profile for your line is - 27.76 Mbps
Upload speed achieved during the test was - 4.94Mbps
Fixes: 514
Re: Slow fibre broadband.
From testing your line, it looks like your router is in sync at a level below what we'd like to see.
I'd recommend plugging the router into test socket as explained here
If that doesn't help, I'd definitely advise to report a fault to us at http://faults.plus.net
pittdj70
Connecting the router directly into the test socket did not help so I have raised a fault.
(The reporting process required a visit to the BT speed checker which requires Flash. I don't want that anywhere near my Mac but downloaded it anyway only to find that the speed checker did not work fully anyway.)
Thanks for your help.
Fixes: 514
It looks like the testing process has detected a potential problem and has reported it through to BT.
We'll provide an update via this ticket when we have more info.
pittdj70
A BT openreach engineer came on the 18th October. He was very good. The line has retrained itself upwards since and is now :-
Current line speed: 45.4 Mb
5. DSL uptime: 0 days, 00:04:56
6. Data rate: 6890 / 47886
7. Maximum data rate: 6890 / 49415
8. Noise margin: 5.9 / 3.8
9. Line attenuation: 30.4 / 21.7
10. Signal attenuation: 29.6 / 20.8
Thanks all round.
Fixes: 231
That looks a lot better!
Fingers crossed it's fixed.
 Matthew Wheeler
