Slow download
digitalfixer65
Slow download
For at least the last week my download speed has been less than half of what I'm paying for.
No problems with the upload speed.
Kevin.
15 REPLIES 15
BrightonRock
Fixes: 8
Re: Slow download
On a wired connection? It is probably worth running through the checks and logging this as a fault even given the time of year so that it is in the queue for action after the holidays. https://www.plus.net/apps/kbdfaults
Fixes: 1,600
Re: Slow download
Hi Kevin.
Our tests are detecting a potential line fault so I've raised that to our suppliers now.
We'll be in touch when we've got more info.
digitalfixer65
Re: Slow download
Thank you.
Kevin.
Fixes: 1,600
Re: Slow download
No problems Kevin.
Fingers crossed it's fixed soon.
digitalfixer65
Re: Slow download
Returning to problem as I've just returned from holiday.
On the advice of the Open Reach engineer who came to my house I moved the Hub One next to the faceplate using supplied cables. I should add that the engineer was getting full speed on his tests.
Connection information on the Hub show 80 Mbps down  and 20 Mbps up.
Speed tests on 3 different devices using wireless and cable gives 17 to 18 up and 30 to 31 down.
Therefore I can only conclude that the problem is further upstream than my connection.
Kevin.
[Edit] Also I had the same results using a BT Hub 5.
digitalfixer65
Re: Slow download
The problem still exists.
Checked today gives the same results as Saturday.
This has been going on now for nearly 2 months.
Kevin.
digitalfixer65
Re: Slow download
Can someone look at this problem please.
Kevin.
MatthewWheeler
Fixes: 479
Re: Slow download
Sorry to hear you're having issues.
Our tests aren't showing any problems.
Can you carry out a speedtest here over a wired connection?
Once you've done that you'll need to click 'Further Diagnostics' and enter your telephone number to upload the result.
 Matthew Wheeler
digitalfixer65
Re: Slow download
digitalfixer65
Re: Slow download
I've done the tests and heard no more. Problem still exists.
Kevin.
MatthewWheeler
Fixes: 479
Re: Slow download
Thanks.
I'd recommend raising a fault here so we can investigate further.
 Matthew Wheeler
digitalfixer65
Re: Slow download
Fault raised as requested.
Since then silence from Plus Net.
This has now been going on for over 2 months and needs to get sorted.
Kevin.
MatthewWheeler
Fixes: 479
Re: Slow download
Can you retest it?
I've made some changes which should help.
 Matthew Wheeler
digitalfixer65
Re: Slow download
@MatthewWheeler
I don't know what you did but speeds are now back to what I had before the problem.
I'll leave it for a week or two and if things are still ok I'll flag this as fixed.
Thank you.
Kevin.
