Slow download speed
- Slow download speed
Slow download speed
07-09-2019 8:24 PM
Hello,
My download speed has been only around 23Mbps instead of 60+ with occasional cut-outs in service over the past few weeks.
Would appreciate any tech support to find a solution.
Message 1 of 2
(427 Views)
1 REPLY 1
Re: Slow download speed
08-09-2019 4:52 PM
Thanks for your post, @pnacc.
We're sorry to hear of this issue.
On checking the line, nothing looks to be out of place, as seen below:
GEA Test Detail | |||
Circuit ID | NA | Service ID | REDACTED |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 79.9 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 171.9 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-08-26T16:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 79.9 Mbps | 79.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-09-08T15:19:50Z | 2019-09-08T15:34:50Z |
Ingress Code Violation | 2 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
On checking the RADIUS (connection) logs, we're showing that there has been a solid connection for the past 17 days and so can you confirm whether this issue is affecting your wired Ethernet connections, or is it solely experienced with your wireless connectivity?
