Slow download speed on wifi.
- Re: Slow download speed on wifi.
28-11-2014 9:18 PM
Getting great speeds when using a cable (77mb and 17mb) however, when I switch to wifi my download speed reduces to 16mb. The speed is irrelevant of distance from the router, I can be a metre away and get the same issue.
Any suggestions or advice ?
Thanks.
28-11-2014 9:55 PM
Make sure you're using WPA2 encryption on your router and that your testing device isn't 802.11g would be my first thoughts... Next would be to change wifi channel
28-11-2014 11:09 PM
29-11-2014 12:58 PM
We'd definitely advise trying what tonyAtplus has mentioned as it can help to get the most out of your WiFi connection.
We have a help page which should help if you decide to give that a try: http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml
29-11-2014 9:45 PM
Thanks for the advice.
I've downloaded the app as suggested, the dBm on channel 6 is around 55. There doesn't appear to be any other interference. I switched to channel 1 to see if there was any improvement, unfortunately there isn't.
Any other suggestions ?
Thanks again.
30-11-2014 11:48 AM
what are you using wifi on?
i would replace it with a router with 5ghz wifi something like the bt home hub 4 will be fine thats what i use and its the cheapest option i got mine for £13 delivered off ebay.
16 meg seems slow though could be interference from something you have in the house like timers baby monitors etc the bt home hub 4 on 5 ghz wont suffer from these problems.
30-11-2014 12:05 PM
Quote from: teabag31 ...on 5 ghz wont suffer from these problems.
That is only true if the client device supports the 5GHz band.
The OP has not clearly indicated what the wifi device is - does it support n-mode?
30-11-2014 2:18 PM
phones tablets tvs have 5ghz from the last 2 years even the crappy sky wifi connector has it
30-11-2014 6:21 PM
Yes, I'm using the Plusnet supplied router (at the moment !)
Testing wifi speed on the latest iPad mini.
Is there a better way of testing wifi speed ?
I've just purchased the Asus RTN66U router but not configured it yet.
Thanks.
30-11-2014 6:52 PM
30-11-2014 7:23 PM
Thanks.
