Slow connection
- Slow connection
Slow connection
06-01-2021 8:36 PM
Re: Slow connection
13-01-2021 10:59 AM
I have a similar problem but much more consistant.
When I first got fibre connection i was getting 17 to 20 Mbps, that was in 2015. Since then the speed has gradually declined, though upto October 2020 I was still getting up to 16Mbps. From October 2020 I have had a lot of connection problem, with connection dropping repeatedly and requiring reboot. Plus arranged visit by Open Reach engineer 3 times. The first 2 times they found fault and "fixed" it, only to recur again. The third visit resulted in supply of a new modem. I don't know how effective this will be.
The point, however, is that with the biginning of the connection problem, the speed also dropped to between 8 and 12 Mbps. Nothing I can do will raise the speed over 12.7 Mbps. I don't understand why the speed has gone down over the years and why it so low now.
Is there a solution to this?
