Slow connection
- Slow connection
Slow connection
02-05-2019 9:16 AM
Re: Slow connection
02-05-2019 10:07 AM
Almost identical to the issue I'm having at the moment: until a couple of weeks ago I'd had a stable download speed of 35 for the duration of my 12-month contract. It dropped to 22 and over the last couple of days it's dropped again to 19. I've got an engineer's visit booked for next week.
Are you connected via Ethernet to the master socket?
Re: Slow connection
02-05-2019 10:10 AM
Re: Slow connection
02-05-2019 10:44 AM
My line profile speed is now 27.7. when I've had 34 for months. I can only assume my line has been changed?
1. Downstream Test: -provides background information.
Download Speed
26.4 Mbps
0 Mbps 27.76 Mbps
Max Achievable Speed
Download speedachieved during the test was - 26.4 Mbps
For your connection, the acceptable range of speedsis 19.43 Mbps-27.76 Mbps .
Additional Information:
IP Profile for your line is - 27.76 Mbps
Upload Speed
6.14 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 6.14Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Re: Slow connection
02-05-2019 1:13 PM
Re: Slow connection
09-05-2019 5:15 PM
Could I request a GEA test to see what my line is now capable of supplying? Thanks.
Re: Slow connection
09-05-2019 8:53 PM
Here is the GEA result;
Test OutcomePass
Test Outcome CodeGTC_FTTC_SERVICE_0000
DescriptionGEA service test completed and no fault found .
Main Fault LocationOK
Sync StatusIn Sync
Downstream Speed43.5 Mbps
Upstream Speed9.1 Mbps
Appointment RequiredN
Fault Report AdvisedN
NTE Power StatusPowerOn
Voice Line Test ResultPass
Bridge TapNot Detected
Radio Frequency IngressNot Detected
Repetitive Electrical Impulse NoiseNot Detected
Cross TalkNot Detected
Estimated Line Length In Metres792.7
Upstream Rate AssessmentVery Good
Downstream Rate AssessmentGood
Interference PatternNot Detected
Service ImpactNo Impact Observed
Home Wiring ProblemNot Detected
TechnologyVDSL
Your router is syncing at 43.5Mbps which is within the 39-54Mbps Estimated Speed Ranger as per DSL Checker
Thanks,
MoR
