Slow connection and loosing sync
edwardw
So for the last week or so my connection has been dropping
I've logged it with support yesterday but not heard back yet ?Huh
The open reach modem would loose sync, connect straight back up and then be ok for a bit then same again. Seemed to happen randomly.
I then swapped my modem with a friends spare, and I don't think it's done it since (haven't been at home as much) so could look like a faulty modem..... however, (can someone upload my radius logs for last 2 weeks?)
There is now a fair bit of packet loss on my line and some high response times too, so not sure the modem was the full issue?Huh
5 REPLIES 5
adamwalker
Fixes: 221
Re: Slow connection and loosing sync
It does sound like an issue with the modem, especially if the issue clears when you tried different hardware.
Are you definitely using an Openreach modem? I ask as your account indicates that we've sent you a Hub One.
Here are the connection logs you asked for:
 Adam Walker
edwardw
Thanks for that - as you can see, ive been connected (id say) forever, since my connection was in, and then as per the graphs there have been a lot of drops in the last week... so something somewhere isnt right!
Yeah, i use an apple airport extreme as my router, so using my original OR Modem, your HubOne is in my garage as a spare Smiley
Can you still ship replacement openreach modems? - As i do notice a drop yesterday morning, not sure it is the hardware? Time will tell i guess!
Can you reset the line profiles?
Cheers
Anoush
Aspiring Hero
Fixes: 139
To answer your questions, no and no. Apologies Sad It's been about a year now since we've had the ability to order Openreach Modems withdrawn. Also, a line can only be reset by an Openreach engineer after a fault has been resolved.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
edwardw
Thanks. My connection hasn't dropped while I've been home today. But still some packet loss on the line. Sad
edwardw
I closed my support ticket by mistake - so i reopened another one
If they could be merged that would be great.
It said there was a fault and it had been cleared - what was the fault?
Im still having issues, disconnected 3 times today according to TB meter
http://www.thinkbroadband.com/ping/share/46b9d2455415c6460dec3979f96cd61f-07-01-2017.html
Ive still got packet loss too - with some high response times
76 packets transmitted, 73 packets received, 3.9% packet loss
round-trip min/avg/max/stddev = 14.123/87.037/1031.535/228.880 ms
Seem to be a few of us with similar issues?
