Slow broadband
- Slow broadband
Slow broadband
21-03-2020 12:54 PM - edited 21-03-2020 12:55 PM
As can be seen by the attached image my line speed is not as it should be:
- Minimum Guaranteed Speed: 73.1Mbps
- Current Line Speed (Download): 14.5Mbps
Could someone help please?
Re: Slow broadband
21-03-2020 2:22 PM
@DMikeW Welcome to the forum.
The first thing to know is whether this speed test was over wireless or whether you have a computer connected to your router using an Ethernet cable.
If it’s wireless then you need to repeat the test using Ethernet. This will show whether you have a network or wireless problem.
Re: Slow broadband
21-03-2020 7:36 PM
My connection is via Ethernet cable, however the speed information is from my plus net login
Re: Slow broadband
25-03-2020 12:55 PM - edited 25-03-2020 12:55 PM
I logged this post on saturday and I logged a case on Sunday and I've not heard anything from either yet - anyone know whats going on?
Re: Slow broadband
02-04-2020 10:56 AM
Thanks for getting in touch @DMikeW and apologies for the delayed response.
I'm sorry to hear that you're having issues with your speeds.
I've tested your line today and I can see that the speeds are quite poor.
Can you raise this online by going here and then post back once you've done so?
That will allow us to get that picked up straight away for you
Re: Slow broadband
02-04-2020 11:18 AM
Hi Matthew,
I logged the issue on the 22nd - reference: 200229548
Re: Slow broadband
02-04-2020 12:30 PM
Thanks for getting back to me @DMikeW
I've just updated it with the next steps.
Let me know once you've responded
