Slow broadband
- Slow broadband
Slow broadband
27-12-2019 5:50 PM - edited 27-12-2019 5:56 PM
My contract is up on the 12th of January and if I can't get this resolved I will have to move to the dark side to get faster speeds.
Re: Slow broadband
28-12-2019 12:53 PM
Re: Slow broadband
29-12-2019 3:36 PM
Hi @Reklaw I'm sorry to see you're experiencing speed problems. I've tested your line today and while I can see your router is now getting a good speed of 37mbps for your length and quality of line, your connection has been dropping frequently within the past week, which had lowered your speeds to around the 23mbps you've mentioned.
Your line speed has picked up to a higher speed as well as the profile on your account, but your download speed looks to be capped at an old profile. If you can reboot your router you should see a higher download speed than you are currently.
There's definitely an underlying issue we'd need to investigate, because our testing is showing your line in bad shape. Unfortunately we're unable to arrange an engineer visit while there's a cease on your line to stop your services.
From experience if we try to book an engineer while this is in progress, the supplier system more often than not simply cancels the engineer visit either outright or at the very last minute.
I'm happy to take this on personally moving forward to try to get this resolved for you, but we'd need to cancel the cancellation request so we can progress the fault. If you're happy to go ahead, can you reply to your fault ticket Here with your availability for an engineer to visit and that you're happy for us to cancel the cancellation request.
