Slow broadband
- Slow broadband
Slow broadband
a week ago
Re: Slow broadband
a week ago
Hi, I also have the fibre extra service and find that fairly regularly I have to reboot the router to get a half decent speed. I mostly use WIFI and have devices on both 2.4 and 5 Ghz. The speed seems to deteriorate over the day and by the following morning I am down to 1Mbs with lots of latency when I do a speed test. By rebooting the router it snaps back to a more acceptable performance although I have rarely seen anything above your speed. It is very frustrating to be sure!
Re: Slow broadband
a week ago
Keeping opening a new topic relating to the same issue is counter productive.
In this post https://community.plus.net/t5/ADSL-Broadband/Slow-promised-speeds/m-p/1601713#M329433 you say your speed should be between 37 and 47 Mbps. This seems very marginal with respect to paying for fibre extra. Have you considered downgrading to the 40/10 service?
Re: Slow broadband
a week ago
Hi @craigszxtt
I'm sorry to hear you're experiencing speed problems.
Our tests are detecting your circuit is on a hot VLAN. This basically means that the part of our suppliers network your connection is routed through at the exchange is congested and having capacity issues.
I've discussed this with our suppliers and they've informed me that they are migrating you to a cooler VLAN - we expect an update within the next 48 hours on this.
I have raised a ticket to your account as well containing information and test results.
Kind Regards,
MoR
MoR Plusnet Help Team |
Re: Slow broadband
Thursday
Regards
Re: Slow broadband
Friday - last edited Friday
Hi @craigszxtt,
I'm sorry that our faults team haven't been in touch with an update yet. I've checked and our suppliers have moved you onto a cool (uncongested) VLAN on the 13th of February.
Your connection is looking better from here, with just one drop since you were moved onto the cool VLAN.
Testing your line isn't picking up any issues at the moment and the line is currently syncing at 46.7mbps, which is within the estimates.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 46.7 Mbps | ||||
Upstream Speed | 11.5 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 854.8 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 05:00 to 05:15 | ||||
Interference Location | Unknown | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Retransmission Low | ||||
Time Stamp | 2019-02-02T11:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 43.7 Mbps | 50.1 Mbps | 47.6 Mbps |
Up Stream Line Rate | 10.7 Mbps | 11.5 Mbps | 10.9 Mbps |
Up Time | 693.0 Sec | 900.0 Sec | 898.9 Sec |
Retrains | 0.0 | 4.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-15T10:42:48Z | 2019-02-15T10:57:48Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please let us know if you're still experiencing any connection problems on your side.
Emily D Plusnet Help Team |
