Slow broadband after phone fault fix
Den1
Hi could some body from CS check my broadband,user name dennisfuggle, after having the phone sorted which now works fine,I find that my broadband speed is half what it should be, getting about 35meg down its normally in the high 60's, modem reports
Current Rate (Kbps) 19999
74873*
Max Rate (Kbps) 21023 72884*
SNR Margin (dB) 6.7 5.3
Line Attenuation (dB) 21.1 16.2
Errors (Pkts) 0 0
* These two are the wrong way round bug in software.
Is this a fault, or a case of waiting for DLM to sort its self after the fault, or can plusnet give it a kick their end ?
Speed tests are done wired
Fixes: 136
Re: Slow broadband after phone fault fix
Your connection hasn't dropped since our profile last updated.
If you can disconnect and reconnect your PPP session your speeds should pick up.
 Matthew Wheeler
Den1
Many thanks now fix't, why didn't i think of that Embarrassed
Fixes: 136
Glad to hear it!
 Matthew Wheeler
