Slow Upload
JB567
Slow Upload
Is there any reason that when I joined Plusnet I was reliably getting 16mb up but now I get no more that 8 - 9 mb? It almost seems as though a limit has been put on the line?Huh
I am on the highest package as far as I am aware.
Re: Slow Upload
What does the BT Speed test show?
JB567
Re: Slow Upload
47 down 9 up
Fixes: 62
Re: Slow Upload
We need the result of the further test - the IP Profiles - as you may be on the 55/10 product and if not then your line has just got worse as mine has due to cross talk
JB567
Re: Slow Upload
BT Speedtest results:
1. Best Effort Test: -provides background information.
  Download Speed
  47.38 Mbps
0 Mbps 47.84 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 47.38 Mbps
 For your connection, the acceptable range of speedsis 38.27 Mbps-47.84 Mbps .
 Additional Information:
 IP Profile for your line is - 47.84 Mbps
  Upload Speed
  8.23 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 8.23Mbps
Fixes: 62
Re: Slow Upload
Your line has just got slower as mine due to more of my neighbours going to fibre
What does this give for estimated speeds http://www.dslchecker.bt.com/
JB567
Re: Slow Upload
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High Low High Low
VDSL Range A (Clean) 59.7 43.8 16.2 10.3 39.8 Available -- -- Yes --
VDSL Range B (Impacted) 44.6 25 13.4 6.1 20 Available
