Slow Throughput After Fibre Install
- Slow Throughput After Fibre Install
09-12-2015 2:46 PM
Afternoon,
Ive recently had fibre installed and looking at my IP profile, it is set incorrectly.
My router is currently in sync at:
Downstream: 59.14 Mbps
Upstream: 11.33 Mbps
My current line speed on your website indicates: 10.5 Mb
BTW Speedtest results show:
1. Best Effort Test:
Download Speed : 8.18 Mbps
2. Upstream Test:
Upload Speed : 2.93 Mbps
Can this please be amended.
2. Upstream Test:
Message 1 of 8
(996 Views)
7 REPLIES 7
Re: Slow Throughput After Fibre Install
09-12-2015 2:49 PM
Message 2 of 8
(619 Views)
09-12-2015 3:05 PM
Download Speed : 22.21 Mbps
2. Upstream Test:
Upload Speed : 3.03 Mbps
It's still no where near the 59/11 mbit im in sync at.
2. Upstream Test:
Message 3 of 8
(619 Views)
09-12-2015 3:10 PM
Download Speed : 9.92 Mbps
2. Upstream Test:
Upload Speed : 9.27 Mbps
2. Upstream Test:
Message 4 of 8
(619 Views)
09-12-2015 4:12 PM
1. Best Effort Test: -provides background information.
Download Speed
9.89 Mbps
0 Mbps 58.62 Mbps
Max Achievable Speed
Download speedachieved during the test was - 9.89 Mbps
For your connection, the acceptable range of speedsis 41.03 Mbps-58.62 Mbps .
Additional Information:
IP Profile for your line is - 58.62 Mbps
Upload Speed
9.05 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 9.05Mbps
I had faster on a standard DSL service which costs less !
Download Speed
9.89 Mbps
0 Mbps 58.62 Mbps
Upload Speed
9.05 Mbps
0 Mbps 20 Mbps
Message 5 of 8
(619 Views)
09-12-2015 4:27 PM
Are you testing from a wired connection to your router, or wirelessly?
Message 6 of 8
(619 Views)
09-12-2015 4:35 PM
And to ask a stupid question, but have you disconnect and reconnect from the router to get the new speed settings since Matthew's post?
And has the speed on Plusnet's site changed yet?
Matthew may have got side tracked after his post.
Message 7 of 8
(619 Views)
10-12-2015 3:06 PM
Hi there @leeashcroft0,
I have run testing on your line today and it's not showing any reason you should be low in speeds, the profile is correct to match the sync speed etc. Therefore, if the checks georgelnx have suggested don't work then you would need to raise a fault here:
http://faults.plus.net
Thank you.
Thank you.
Message 8 of 8
(619 Views)
