Slow Speeds
Slow Speeds
Just wondering if there is a problem in my area, just hit some really low speeds this morning, its relatively half of what the download speed should be and normally is.
 http://www.speedtest.net/result/6472898708.png
12 REPLIES 12
Fixes: 248
Re: Slow Speeds
Hi @Beermonsta,
Nothing is flagging up during testing, however your sync speed (25Mbps) is definitely lower than I'd expect, given the estimates for your line.
Could you go through our troubleshooting guide here and if you continue to experience problems after this, please report a fault and let us know once you've done this.
Thanks.
 Harry Beesley
 Plusnet Infrastructure Operations Professional
Re: Slow Speeds
Thanks for the reply Harry,
I have a suspicion to what the problem is, Ive had a fair few disconnections these past few days due to a dodgy electricity supply, It may be that Plusnet or Openreach are limiting my speeds thinking there's a fault somewhere!
Strange that its only just kicked in though, but the speed is slowly on the rise.
http://www.speedtest.net/result/6474082725.png
Fixes: 866
Re: Slow Speeds
It looks like your line is banded.
Profile Name 0.128M-25M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off
I've sent your account over to my colleagues to request Openreach to reset your line. It should be done on Monday.
Let us know how it goes.
Aspiring Hero
Fixes: 49
Re: Slow Speeds
Can you reset fibre lines now?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Re: Slow Speeds
Thanks Anoush,
Ill let you all know Monday night if all goes well!
Fixes: 866
Re: Slow Speeds
It's a trial process.
@Beermonsta wrote:
Thanks Anoush,
 Fingers crossed!
Re: Slow Speeds
I dont know if Openreach have done or fixed anything, but its worse than it was before, Anoush.....http://www.speedtest.net/result/6481638568.png
Ive been out all day and my cabinet is visible from my property, so I cant tell you if OR has been or not, is there any notes on my account?
Glenn
Fixes: 866
Re: Slow Speeds
Hi Glenn,
It looks like the e-mail we sent over to our suppliers didn't get picked up, because the trial process to remotely reset a fibre line ended on the 21st July. Sad We'll need to progress this the usual way by arranging an engineer visit.
If you've done the usual checks here can you report the fault to us at http://faults.plus.net
Re: Slow Speeds
Done, Its becoming a pain in my [-Censored-] now Anoush, no wonder why a number of users are moving away from BT owned internet!
But thanks very much
Glenn
Fixes: 248
Re: Slow Speeds
Thanks Glenn, I've got that raised with our suppliers for you.
 Harry Beesley
Re: Slow Speeds
My speed seems to be back to normal now from the speedtest I carried out just now, so Ive closed the ticket.
https://www.thinkbroadband.com/speedtest/1501321675541934055
Glenn
Fixes: 248
Re: Slow Speeds
Glad to hear that, thanks for letting us know Thumbs_Up
 Harry Beesley
