Slow Speeds and connection dropping
justjoe1
For the last moth we have been experiencing a lot of issues with the connection dropping, this evening alone its dropping every 5 or so minutes, also previously I was getting around 70 Mbps down however I did a test today and it was in the 25Mbps range.
Is it possible that a test can be done on the line?
Thanks,
Joe
Fixes: 203
Re: Slow Speeds and connection dropping
Sorry to hear you're having issues.
Our tests are showing a external fault on the line so we'll get that raised for you.
As soon as we know more we'll update you.
 Matthew Wheeler
justjoe1
Thanks for your help Matthew.
