Slow Speeds When Downloading
- Slow Speeds When Downloading
26-02-2020 1:44 PM
Im downloading a game on my Xbox. But when I do anything like downloading. Anything else that requires the internet, goes super slow. I cant stream on netflix, due to me downloading. So I have to stop the download of my game, If I want to watch netflix. Internet browsing isnt the best, when downloading also.
Soon as I stop the download everything else works perfectly. Surely this should not be an issue, considering Im on Fibre.
I did a speed test and I got this:
Download Speed (Mbps): 32.71
Upload Speed (Mbps) : 6.99
Ping Latency (ms): 34
Re: Slow Speeds When Downloading
26-02-2020 4:08 PM
It depends on how much you're downloading and the remote source data rate. There is no QoS control on Plusnet hubs and you can only have your bandwidth once.
You don't say which hub you are using, if it's the old BT modem plus Hub Zero combination then buffer bloat could also become an issue.
27-02-2020 12:00 AM
02-03-2020 5:52 PM - edited 02-03-2020 5:53 PM
Hi @JwattsUK,
Checking from this side everything is looking spot on to the router and with barely any drops, and with speeds of 40Mbps as show on the graph below. Are all of your devices that you are having trouble with at home connected via a wireless or wired connection?
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 40.0 Mbps |
Upstream Speed | 10.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 296.4 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream traffic detected |
Technology | VDSL |
DP Type | External |
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2020-02-18T17:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 39.9 Mbps | 39.9 Mbps | 39.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 567.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-03-02T17:17:14.452+00:00 | 2020-03-02T17:32:14.452+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
