Slow Speed / DLM reset
cgordon
Hi i noticed that my download speed has dropped alot, i have been looking at old speed tests and over the last year or 2 i have dropped from high 30's - low 40's Mbps to mid 20's at best
Could i get a DLM reset maybe to try get it back up to what was was getting?
14 REPLIES 14
Legend
Fixes: 255
Re: Slow Speed / DLM reset
Welcome to the forums, @cgordon . A DLM reset may not resolve your perceived problems. Sight of your Help desk tab (with personal details removed), and the result of a BTW Performance Tester (Advanced Diagnostics) would possibly be a better place to start
cgordon
Screenshot 2021-09-04 at 20-30-24 BTW Performance Tester.pngScreenshot 2021-09-04 at 20-31-55 Broadband Member Centre Plusnet.png
My current line speed is below the minimum guaranteed speed and i have multipul saved speed tests from 2019 and 2020 of my download speed at 38 Mbps and even as high as 44 Mbps
Legend
Fixes: 255
As you say, your current line speed is below the guaranteed minimum, but we need to discover why. Sight of your Help Desk tab from the router would possibly give us some insight.
cgordon
i dont use the plusnet router, what infomation would you like to see?
Legend
Fixes: 255
Which router do you use? We really need your router statistics - Noise margins &c.
Mustrum
Fixes: 77
Also sync speeds and attainable speeds
Sight of the result of entering your phone number in the BTW DS:L Checker  will also help - hide your phone number though.
cgordon
Legend
Fixes: 255
Something is definitely a bit flaky there, but I can't work out what. Did you spot @Mustrum 's edit asking for details of the BT Broadband checker?
cgordon
Thanks il do one in a moment,
i have had the issue before a good few years ago,  been with plus net years and years last time DLM reset bummped me back up to around 40Mbps thats why i asked for one.
cgordon
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper
High Low High Low
VDSL Range A (Clean) help 49.4 35 7.9 6.1 32.4 Available Available --
VDSL Range B (Impacted) help 48 32.4 7.8 5.6 27.4 Available Available --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 50 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 14.5 -- 12.5 to 16 Available -- Yes
WBC ADSL2+ Annex M Up to 14.5 Up to 1.5 12.5 to 16 Available -- Yes
WBC Fixed Rate 2 -- -- Available -- Yes
Observed Speeds VDSL
Max Observed Downstream Speed 32.39
Max Observed Upstream Speed 6.4
Observed Date 2021-06-20
Other Offerings Availability Date
VDSL Multicast Available
ADSL Multicast Available
Premise Environment Status
Bridge Tap N
VRI N
NTE FacePlate N
Last Test Date 26-08-2021
Exchange Product Restrictions Status
FTTP Priority Exchange help N
WLR Withdrawal help N
SOADSL Restriction help Y
Mustrum
Fixes: 77
Thanks. Whilst a DLM reset will no doubt increase your speeds again, you really should chase PN to sort out the underlying problem which keeps reducing your speeds.
How is your phone line, any noise or crackles, dial 17070 option 2 - is it your number and is it quiet?
cgordon
thanks, phone line seems fine the speed will be stable for years at a time then i notice a drop its not like a drops every week or even month, this is the second time in 10 years id guess, only noticed it recently with the kids home lots ran a few speed tests
2018 41.6 down
2019 38.1 down
in 2020 i have one 28.5 down
and now its low to mid 20's
adam945
Fixes: 113
Hello @cgordon
Thanks a lot for reaching out. It appears that on 21/08/2021, the line cut out 52 times, there's no way of knowing introspectively why, but I can see that DLM did slow the line down, and capped your download speed to 30Mbps as a result of this.
Going forward, I've raised this issue with my colleague, who will be requesting a DLM reset with our suppliers, please allow around three working days for this to be completed.
Current profile - Downstream: 0.128M-30M with Retransmission (High). Upstream: 0.128M-20M with Retransmission (Low)
 Adam
 Plusnet Help Team - Leeds
dougjbarnes1
Funny but I'm seeing the same, my usual speed is about 32M down. 8.5M up, but over the last week the rate has dropped, using BroadBandSpeedChecker I Get
Ping     Download      Upload
10 ms   23.97 Mb/s   7.92 Mb/s
We had a power outage about 10 days ago, so the router has been rebooted . I suspect the speed drooff since then but I didn't check for a few days so can't confirm the two correlate
