Slow Line Question
wickyb
Slow Line Question
Hello
My modem connects at 79999 and this seems to be fairly consistent.  Since the beginning of May the real world throughput has been about 50Mbps which is below my guarantee.  Are there still such things as profiles that may have been inadvertently changed on my account?  Any mods able to check or advise please.  Any other ideas?
7 REPLIES 7
Fixes: 1,483
Re: Slow Line Question
Sorry mods are just customers like yourself Smiley
Hopefully a staff member will be along shortly.
First question is whether you are running speed tests wired or wireless?
wickyb
Thx 😉
And wired test. Also have a fingbox wired which is telling me the same thing.
Fixes: 1,600
*Goes back out of the door slowly*
Hiya @wickyb
I've tested your line and we're not seeing any issues or congestion at the exchange, your connection seems to be stable too, however I can see you've completed a BT performance test and that's showing a throughput of 51mbps.
Is your computer plugged into your router using an ethernet cable with no switches or powerline adapters in place?
wickyb
@Gandalf
Thanks for that. Yes - PC tested direct into router. I also have a Fingbox plugged directly into the router and I can see the line speed dropped on the morning of 2nd May sometime after 07:58 and before 11:59 (07:58 was the last ‘normal’ speed test conducted by the Fingbox). The Fingbox results match those that I am seeing through my wired PC.
The router remains connected at 79999 and has been stable so it does look like something is throttling somewhere since 2nd May?
Jubby
All Star
Fixes: 31
Hi @wickyb,
Thank you for confirming.
I have carried out a more intrusive test on the line and haven't been able to identify anything causing this decrease in throughput. Could you remove all devices connected to the router except one which is connected by Ethernet then run a speed test through the BT Wholesale website. You will be presented with a screen that allows you to run further diagnostics, then enter your telephone number and run the diagnostics to send the results to the server.
Once complete, raise a fault and let us know on here so we can look towards progressing the matter with our suppliers.
Thank you.
 Lewis G
 Infrastructure Operations Professional
wickyb
ok - Connected the modem directly to the master socket with nothing else in circuit.  Hard wired to fixed PC for tests.  Also tried a different modem and wire.  Similar results.  Modem continues to connect at a stable 79999 but throughput around 50-60 mbps and similar on BT Wholesale speed tests.  QuestionID is .  Something changed on 2nd May, but doesn't seem to have affected the sync rate at all.
MatthewWheeler
Fixes: 479
Thanks for getting back to us @wickyb
I can see you've reported a fault regarding this and we'll get this picked up for you shortly
Apologies for any inconvenience caused
 Matthew Wheeler
