Slow Fibre speeds 52mbps
Teddy1968
Hi. my speeds have dropped from around 70mbps to 52 mbps for the last couple of weeks. Tried a new router and filters, checked the line for noise and its totally quiet. Can only think it could possibly be a problem at the exchange. Dslam issue maybe? Added Tp link router connection details
3 REPLIES 3
Teddy1968
Re: Slow Fibre speeds 52mbps
Added Speedtest
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
Tibzor
Fixes: 25
Hi @Teddy1968
Sorry to hear about issues with your broadband. I have looked into history of your connection and maximum speeds I can see in last 28 days are up to 60Mbps.
Current speeds are still within estimates for your line.
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
