Slow Fibre Speed
- Slow Fibre Speed
Slow Fibre Speed
27-09-2018 7:38 PM
Currently running at 6mb and below! Usually 25mb
Have rebooted the router and the wifi
Phone line fine
Speed test done wired not via Wifi
Any ideas?
P.S. chat not working and a 20 minute wait for calls to be answered not good
Re: Slow Fibre Speed
28-09-2018 11:28 AM
Hi there, I've just tested your line and it looks like there might be a fault. I'd rule out the checks here first of all https://goo.gl/tu2WWu once that's been done you can report it at http://faults.plus.net Do let us know when you have so we can follow things up with you. - Adam
10-10-2018 8:35 AM
Hi Adam
Did the fault report but have heard nothing yet...
H
10-10-2018 1:45 PM
14-10-2018 8:57 PM
If the work has been done then it has had no effect - if anything it's slower.
Could you let me know what's going on please?
15-10-2018 3:10 PM
Sorry to hear this.
Unfortunately it looks like this didn't work.
We've sent it off to our suppliers to ask them to manually reset the line.
This should be done in the next 24 to 48 hours
24-10-2018 8:47 PM
Just to let you know - engineer turned up on time and fixed the fault. Many thanks
25-10-2018 10:42 AM
