Slow Fibre 12 - 18 Mbps
headonastick
Recently moved home I am using the exact same equipment to connect and my broadband is really slow by the standard I was receiving, no online chat, ridiculous waiting time on the phone so annoyed with Plusnet!!!!
6 REPLIES 6
rongtw
Fixes: 12
Re: Slow Fibre 12 - 18 Mbps
What should you be getting ?
Browni
Aspiring Hero
Fixes: 60
Ad blockers & script blockers can prevent online chat from working.
gofaster
The piece of equipment that affects your speed the most is the wire that connects your house to the local fibre cabinet.
If you moved home you are unlikely to be using the same wire.
What is the estimated speed for your new location?
headonastick
When I said "same equipment" I obviously meant PC, network card and router I am not thick enough to think I would be using the same wire!
Should be around 35mbps
geek26
I would advise you raise a speed fault in this case at faults.plus.net
James
Chris
Legend
Fixes: 169
Can you try a disconnect/reconnect on the router for me please. You should be seeing better speeds now.
