Slow Fibre 12 - 18 Mbps
- Re: Slow Fibre 12 - 18 Mbps
15-10-2016 11:31 AM
Recently moved home I am using the exact same equipment to connect and my broadband is really slow by the standard I was receiving, no online chat, ridiculous waiting time on the phone so annoyed with Plusnet!!!!
15-10-2016 1:48 PM
What should you be getting ?
15-10-2016 1:53 PM
Ad blockers & script blockers can prevent online chat from working.
15-10-2016 6:25 PM
The piece of equipment that affects your speed the most is the wire that connects your house to the local fibre cabinet.
If you moved home you are unlikely to be using the same wire.
What is the estimated speed for your new location?
22-10-2016 8:24 PM - edited 22-10-2016 8:24 PM
When I said "same equipment" I obviously meant PC, network card and router I am not thick enough to think I would be using the same wire!
Should be around 35mbps
22-10-2016 9:00 PM
24-10-2016 10:01 AM
Can you try a disconnect/reconnect on the router for me please. You should be seeing better speeds now.
