Slow Fiber Speed
amhorwood
Slow Fiber Speed
Evening,
I seem to have a very slow connection, I have had it about a week.
Could this please been looked into?
BT Speed test: 1.89 down, 12.38 up and 36 ping latency - I cant get the other bit as the site needs flash!
Phone exchange: MELKSHAME
stimated line speed: 55Mb (This may vary between 60Mb and 79.4Mb) - Checked on 2016-10-30 09:16:18
Current line speed: 2 Mb
6 REPLIES 6
amhorwood
Re: Slow Fiber Speed
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
  Download Speed
  1.91 Mbps
0 Mbps 56.78 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.91 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-56.78 Mbps .
 Additional Information:
 IP Profile for your line is - 56.78 Mbps
  Upload Speed
  13.1 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 13.1Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Test 3 (TAP3)
Upload : 14.07
Ping: 19.50
FAQ
  Download Speed
  6.36 Mbps
0 Mbps 56.78 Mbps
 Download speedachieved during the test was - 6.36 Mbps
  Upload Speed
  3.21 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 3.21Mbps
Your service was found to be performing poorly.
MatthewWheeler
Fixes: 479
Can you try rebooting your router?
I think I may have sorted this for you.
 Matthew Wheeler
amhorwood
WOW, that does look to have sorted it out. Can I ask what the issue was?
MatthewWheeler
Fixes: 479
For some reason a incorrect profile had been applied to your account.
Glad to hear that's fixed the issue.
 Matthew Wheeler
amhorwood
Thanks Matthew, now running at 4.4M/s.
Excalibre68
Just a thought but isn't 4.4MB/s on an 80/20 package seriously slow.
I had 4.7MB/s on a 40/10 package.
4.4 x 8 = 35.2 so you are getting around 36Mb connection.
Asus Rampage V Extreme X99 , Intel i7 5960X @ 4.7Ghz , 32Gb Corsair Vengance 3200Mhz
Corsair Dual Loop Liquid Cooling , 480Gb Samsung EVO 850 HDD , WD 2Tb Hybrid HDD
EVGA 980Ti Classified , Creative Recon 3D Sound , Corsair HX1200i PSU
Logitech Z5500 5.1 Sound System , Corsair Graphite 760T Case
