Slow Evening Speeds
FIXED- Subscribe to RSS Feed
- Re: Slow Evening Speeds
on 13-05-2018 8:22 PM - last edited on 13-05-2018 9:13 PM by Mav
I have recently upgraded from ADSL to Fibre and every evening from around 6pm onwards, the throughput speed drops from around 37mbps to as low as 9mbps. I spoke to a gentleman over the weekend and it was suggested I could be moved to a less hot connection as it was likely due to congestion, but someone would get back to me.
I have gone through general troubleshooting and since i got an extra hub one with the upgrade I have swapped to that together with all the new cables and I am currently connected directly to the master socket and I am using an Ethernet cable. There may be some low level background buzz on the phones but nothing I would otherwise notice and from what I am told by family, the connection is good during the day with consistently high speeds.
I currently have an open ticket 174464039
http://www.speedtest.net/result/7304258208.png
1. Product name: Plusnet Hub 2. Serial number: +081441+NQ80567040 3. Firmware version: Software version 4.7.5.1.83.8.237.2.2 Last updated Unknown 4. Board version: Plusnet Hub One 5. DSL uptime: 0 days, 06:11:51 6. Data rate: 9997 / 39950 7. Maximum data rate: 30038 / 90587 8. Noise margin: 18.9 / 20.4 9. Line attenuation: 7.6 / 9.3 10. Signal attenuation: 7.4 / 9.4
Moderator's note by Mike (Mav): Post released from Spam Filter.
Fixed! Go to the fix.
14-05-2018 1:50 PM
Hi @rd1956, I'm sorry that you're experiencing poor speeds during the evening.
I've tested your line today and, as you've mentioned, it's currently showing that the equipment that you're connected to at the exchange (the VLAN) is congested. I've asked our suppliers to move you onto a "cooler" (less congested) VLAN and they have advised that this will be done within 24-48 hours.
Our faults team will be back in touch once you've been moved over, if the issue is still ongoing at this stage they will investigate further for you.
14-05-2018 1:56 PM
Thank you, very much appreciated.
16-05-2018 8:42 PM
Currently getting 37.5 down at peak time and not noticed any slowdown this evening.
Looks like issue is resolved.
Thanks again for the help.
17-05-2018 9:42 AM
