Slow Download, Fast Upload
- Slow Download, Fast Upload
02-08-2021 3:44 PM
1.79 Mbs Down
18.01 Mbs Up
Supposed to be around 65-70 Mbs down
Any help
Re: Slow Download, Fast Upload
02-08-2021 5:56 PM
Is the username correct?
02-08-2021 6:21 PM
02-08-2021 6:40 PM
@Buzzb123 Well that's wrong it should be your own username in the form username@plusdsl.net and the password you use to loin to the your member centre account.
02-08-2021 7:10 PM
02-08-2021 7:56 PM
You could try a router factory reset by holding the reset button in for around 30 secs then leave the router for 10 minutes or so, it may pick up the correct username and password from Plusnet. If that doesn't work you need to change the connection details yourself in the router or your broadband will not work properly.
02-08-2021 8:24 PM
02-08-2021 8:36 PM - edited 02-08-2021 8:39 PM
@Buzzb123 You never said you weren't activated yet, it isn't going to work. Surprised you can get any connection at all. Stop wasting my time.😀
02-08-2021 9:09 PM
02-08-2021 10:07 PM
@Buzzb123 Why post in the forum then, I guess you wanted someone to help or give advice.
