Slow 2.4Ghz Wireless.
stexde
I have a TP-W9980 router, updated to latest fw.
I've noticed my wireless speed has dropped massively from 65Mbits to 8!
Not sure if my router is suddenly dodgy - no changes in other equipment.
However I checked my router config to find:
Firmware Version:0.6.0 1.13 v0021.0 Build 160125 Rel.52064n
Hardware Version:TD-W9980 v1 00000001
System Up Time:0 day(s) 00:27:33
DSL
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/B/L/M
  Upstream Downstream
Current Rate (Kbps) 19999 66997
Max Rate (Kbps) 32594 82539
SNR Margin (dB) 13.5 10.3
Line Attenuation (dB) 15.8 13.1
Errors (Pkts) 0 344344
Help, as i'm flummoxed, thanks!
Wired test:
http://www.speedtest.net/my-result/5236120241
stexde
Re: Slow 2.4Ghz Wireless.
There is horrendous crackling and popping from time to time on the phone too. Has been occurring for years but multiple BT engineers unable to find a fault.
pwatson
Have you tested your speed using a wired connection?  Given that you've got a noisy line and lots of errors it would seem likely that this is nothing to do with wireless?
Follow the steps on http://faults.plus.net to submit a fault report...
stexde
Wired test - was in first post too.
pwatson
Oops - Apologies!!
Suggest you try changing the router wifi channel then - Try channels 1, 6 and 11 to see if there are any improvments.
