Slooooooooooooooooooooooow speeds...seriously slo o o ooooooooooooooowwwwwwwwwwwww w
- Re: Slooooooooooooooooooooooow speeds...seriously ...
14-02-2021 12:11 AM
Hi. new customer. moved from talktalk...to be honest they werent actually that bad, had great speeds etc but saw the ads on tv and competitive price so switched. literally moment we went live and router went on we were hitting massive figures of 5 down and 3 up...this is on fibre extra. we dont live in a mansion, not streaming constantly, only have about 4 devices in use, we zoom daily but we use our O2 data through hotspot from smartphone because router drops out. we are only about ten meters away from the router. our estimated speeds of 69-72 down and 17-18 up have never been achieved. so openreach were sent out...problem was the router...new router arrived...speeds still no better. even with ethernet cable attached the most we achieved was 21 up and 13 down. havent even been customer for one full month and have really had enough. we are reaching roughly between 7-11 down and 2-9 up daily now. we're constantly having to buy extra data for our mobiles as we cant use the wifi. really have no idea now what to do next. any suggestions??
Re: Slooooooooooooooooooooooow speeds...seriously slo o o ooooooooooooooowwwwwwwwwwwww w
14-02-2021 8:37 AM
What speed do you get?
Then try the same test using wifi.
10m away though a couple of walls or on the top floor is a long way for wifi.
14-02-2021 9:00 AM
thanks for your reply. weve used ethernet cable to laptop to test speed and achieved 21 up and 13 down. ive used the bt wholesale, plusnet and the ofcom checkers and all roughly the same. wifi readings are ever so poor averaging 7-11 down and 2-9 up. the router is in the hallway and ive been testing wifi in my kitchen directly behind the hallway, about 10metre distance and no walls furniture etc in way and still very poor. ive tried wifi test readings stepping increments of metre or two at a time towards the router and still so poor. ive seen on lots of reviews that people are suggesting using bt homehub 6 so im gonna try that now and see if its any better
Re: Sloooooooooooogooooooooooow speeds...seriously slo o o ooooooooooooooowwwwwwwwwwwww w
14-02-2021 9:10 AM - edited 14-02-2021 9:24 AM
Does your phone app show other strong wifi signals on the same channels?
21 up and 13 down does suggest a BB fault. Is the phone line quiet? No pops, clicks, crackels
Here, for example, my neighbours wifi degrades my 2.4G and makes it slow but the 5G is fine. Thier box channel hops - nowt I can do about it. 🙂
14-02-2021 9:22 AM
yeah tried that moving router. phone line had a fault few days ago which has now been dealt with. my dads ex BT engineer and he suggested using the hh6 router too so im picking one up lunchtime and fingers crossed itll work
14-02-2021 9:27 AM
Still check for interferance or screening though. Moving the HH6 nearer to your "action center" is allways a "good thing" 🙂
14-02-2021 10:02 AM
id stand on one leg on the shed if it meant getting some better speeds hahahhahahhahah
