Sky to Plusnet
LaurenB
Fixes: 61
Re: Sky to Plusnet
Thanks for getting back to us @SJMC1, I'm really sorry for the ongoing issues. I can see your fault ticket has been picked up by our faults team this morning and so I have provided the latest information on this here for you.
 Lauren Barry
SJMC1
Re: Sky to Plusnet
The fault still isn't fixed and the disconnects are as bad as ever!
BD
Fixes: 72
Re: Sky to Plusnet
Hi @SJMC1, thanks for getting back to us and I'm sorry to hear the drops look to be persisting. With the drops occuring so intermittently it does make it trickier for our suppliers in locating the cause of the issue and why I beleive your previous engineer visits don't look to have resolved the problem. I've looked into and updated the fault on your account that requires your attention and can be seen here:
https://www.plus.net/wizard/?p=view_question&id=217188395
Feel free to give us a nudge on here once you've updated the ticket then we'll happily look into progressing this further for you.
 Ben Devine
 Plusnet Help Team - Sheffield
SJMC1
Re: Sky to Plusnet
Ticket updated
Fixes: 1,139
Re: Sky to Plusnet
I've booked the engineer and updated the ticket ref 217188395 with the appointment details.
Let us know how the appointment goes.
SJMC1
Re: Sky to Plusnet
I had the engineer out on Monday and he found no fault and that the line was good. He found no drop outs from the ports in the cabinet and that it was likely a profile issue with  plusnet. I'm still getting these disconnections.
adam945
Fixes: 48
Re: Sky to Plusnet
Hello @SJMC1
Thanks for letting us know. There's no such thing as a profile issue from our end if I'm honest. You're connecting through PTA which means' we aren't able to manually adjust your connection speed, and your Broadband profile on BT Wholesale's end is not banded at all.
Current profile: Downstream: 0.128M-80M with Retransmission (Low). Upstream: 0.128M-20M with no error protection
I'll pop a visual radius below which shows that the line is disconnecting around one a day in the early hours of the morning, though no issues are being found with the network itself. Are you using the Plusnet hub One? Tests on my end appear to show that it's offline?
If you're not, have you tried using it to see if this improves your connection?
Ignore the dropouts on Monday afternoon, this was during the engineer visit.
 Adam
 Plusnet Help Team - Leeds
SJMC1
Re: Sky to Plusnet
I have plugged the hub one back in. I'll see how that goes.
SJMC1
Re: Sky to Plusnet
The disconnections are still happening with the plusnet router as well.
adam945
Fixes: 48
Re: Sky to Plusnet
Hello @SJMC1
Thanks a lot for letting me know and I'm sorry to hear that the dropouts are still happening. Looking at the visual radius below, can you confirm whether you're seeing more dropouts than those displayed?
On our end, looks like the line has been dropping out at around 1AM briefly for the last few days. These do appear to have improved though since you plugged in the Hub One.
 Adam
SJMC1
Re: Sky to Plusnet
That looks about right. My download speed has also reduced each time as well
SJMC1
Re: Sky to Plusnet
On my router the time stamp is one hour behind. All the router logs are one hour behind. The router records show that the last disconnect was at around 12 last night but I know from the router DSL up time and your records provided by you shows that it was around 1 am that it disconnected. My own router that I had connected a while  back showed the time one hour behind as well I had to change it manually. Is there something  wrong with my profile somewhere?
adam945
Fixes: 48
Re: Sky to Plusnet
You're right @SJMC1
I've just run an RRT on the line which does show that speeds have been fluctuating, and have recently decreased.
This is likely due to the dropouts you've been having, which have caused DLM to band your line at 55Mbps.
Current Profile - Downstream: 0.128M-55M6dB with Retransmission (High). Upstream: 0.128M-20M with no error protection
As the drop outs are few and far between lately though, especially over the last few days, I wouldn't say this constitutes raised a fault yet, but if they get worse, let us know.
In regards to the banding issue, I'll get this raised with my colleague in order to get this reset, this should take around three working days.
 Adam
SJMC1
Re: Sky to Plusnet
I'm just getting these disconnections. The same thing is happening again the speed is also dropping soon my li e will be banded again. Please see router logs attached. One is at time of disconnection and the other is it blocking traffic and packets being out of sync. Note the time stamp on the router logs is an hour behind.20210917_084347.jpg20210917_090426.jpg
adam945
Fixes: 48
Re: Sky to Plusnet
Hello @SJMC1
Thanks a lot for your response and for providing us with the router logs. It appears that quite a few packets with the same outgoing IP are being blocked for some reason, and that the router continuously needs to re-configure itself.
Going forward, I'd be happy to order a new router to see if this does the trick, would you like me to get one sent out?
 Adam
