Sky to Plusnet
- Sky to Plusnet
Sky to Plusnet
13-08-2021 4:27 PM
I've been with Plusnet just over two weeks after leaving Sky fibre broadband. I currently have 58Mbps download speed with plusnet at about a 6 dB SNR, with Sky I had about 68Mbps and an SNR of about 3dB. I was wondering with it being the same line why the speeds ain't about the same. I have noticed some disconnects.
Re: Sky to Plusnet
13-08-2021 4:49 PM
Re: Sky to Plusnet
14-08-2021 9:09 AM - edited 14-08-2021 9:10 AM
Good morning @SJMC1
Thanks for reaching out, tests on your line this morning appear to show that it's operating within estimated speeds, syncing at 55.7 Mbps, though the line itself can handle up to 64.5, and disconnections can be seen on the visual radius graph, which you can see below.
I can't really speak for other providers, but what I would say is that Sky are what we call an MPF provider, and use different equipment at the exchange, so this MIGHT be the cause of the differing speeds.
If the disconnections continue, I'd advise going through some basic troubleshooting here.
When testing, if you can, remove the faceplate from your master socket, and connect your router directly into the test socket which lies behind it, avoid using any extension cables / sockets as well.
If that doesn't help, please complete the questions on the fault that you've raised, and our faults team will pick this up on our end.
Re: Sky to Plusnet
15-08-2021 6:01 PM
Hi @SJMC1
If the disconnects are manual router reboots in an attempt to increase the speed, then it will be counter productive.
When changing ISP's Openreach reset the Dynamic Line Management (DLM) and DLM re-learns the line characteristics.
If the errors are low DLM will automatically reduce the noise margin in 1 dB steps and at each reduction check the line is still stable.
The disconnects will be seen as errors and if DLM regards the errors as too high will stop the process of reducing the margin and increasing the speeds.
Regards
Richard
Re: Sky to Plusnet
16-08-2021 5:09 PM
The disconnects are not from my end as I know the issues about rebooting the router and DLM.That's what I am afraid the system thinking there was a fault in the line. I had none of them issues with sky. The only time I switched the router off with being with Plusnet was the other day. I went into router settings and clicked disconnect first. I then replaced it with my own equipment but the disconnects are still happening. I fear if this keeps happening the DLM will make my line worse.
Re: Sky to Plusnet
17-08-2021 10:04 AM
Hi @SJMC1,
I'm sorry to hear that you're experiencing issues with the connection. I've taken a look into your account today and whilst we can see there have been some drops, we're not detecting any underlying faults on the line. I can see that you've started to raise a fault online, but it doesn't look like this process has fully completed. So we can review the situation further, please could you confirm what troubleshooting steps you've been able to carry out at this time?
Re: Sky to Plusnet
17-08-2021 12:34 PM
Phoneline sounds clear. Replaced all equipment including microfilter. Plugged into test socket. Still disconnects and I'm also getting a lot of buffering and web pages not loading up right.
Re: Sky to Plusnet
17-08-2021 3:33 PM
Thanks for confirming this @SJMC1. Please could you confirm what time you set the router up in the test socket? I can't see any further drops since I'd reviewed the account earlier on this morning, so it may be worth monitoring it for a couple of days to see if the connection remains stable. When you're connecting at the moment, are you connecting via Wi-Fi or Ethernet cable?
Re: Sky to Plusnet
17-08-2021 3:41 PM
I plug my new microfilter into the test socket a couple of days ago. I'm using both wifi and wired.
Re: Sky to Plusnet
17-08-2021 6:51 PM
Hi @SJMC1, thanks for getting back to us and confirming the checks you've done already your side. I've updated and progressed the fault on your account that now requires your attention so we can progress this further for you.
The ticket I've added to your account that can be seen and commented on here:
https://www.plus.net/wizard/?p=view_question&id=217188395
Feel free to give us a nudge on here after replying on the ticket then we'll happily look into picking up and progressing this issue further for you.
Re: Sky to Plusnet
27-08-2021 11:16 AM
It's been a week since the engineer was out and the disconnects are still happening. Speed has also when down from 60Mbps to around 40Mbps this morning.
Re: Sky to Plusnet
27-08-2021 2:34 PM
Hi @SJMC1,
I'm sorry to hear that this is the case. I've reviewed your account this afternoon and whilst we can see there have been a few drops in the last week, the speed is running within the estimated range. Have you noticed any sort of pattern behind the drops? From what I can see they seem to be occurring in the early hours of the morning - are you noticing your connection dropping at any other times throughout the day?
Re: Sky to Plusnet
27-08-2021 3:25 PM
From what I can see it's at night. The engineer replaced the bt socket and reset the line. The speed went back up to 60 Mbps and he said the line was good, but the disconnects are still happening. When I was with sky the other month I had a sync speed of 68Mbp and no issues.
Re: Sky to Plusnet
27-08-2021 6:23 PM
Thanks for confirming this. Has anything changed in the property since the engineer replaced the BT socket? For example, the location of the router. We may need to arrange an engineer visit to investigate the line further and if you would like for us to do so, I've updated the open fault ticket on your account concerning this, here.
Re: Sky to Plusnet
27-08-2021 6:40 PM
Nothing in the house has changed since the engineer visited. Every else in the house has been the same since I've been with sky as well.
