Sky On Demand Problems
auchavanbluenos
Recently upgraded from PlusNet Broadband to PlusNet Fibre.
Newer laptops and iPads etc.. all worked okay but had to switch on IPV6 in network setting on older macbook, which now works fine.
One remaining problem is I can't get Sky On Demand services as Sky Box not on internet.
I have a wired connection to the box which worked fine before.
Network Screen on Sky says :
Connection to Broadband Router - Fail
Connection to On Demand FAIL
IP Address 0.0.0.0
DHCP ON
Any suggestions to remedy ?
1 REPLY
Re: Sky On Demand Problems
Check cable and Reboot the sky box  Huh
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
