Sites very slow
bsoord
Sites very slow
Hi everyone
For the past week or so the web has been very slow (hard wired connection) - sites like BBC taking an age to load and images timing out. Same with Twitter and other sites.  BT Wholesale is reporting 25mb down (acceptable range 40-67), 12mb up.  I've noticed a few people here reporting similar problems.  Any ideas?
thanks
Bruce
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: Sites very slow
You should be seeing faster than 25Mb/s on a speedtest. If the speeds remain slow it's worth reporting as a fault to us at https://faults.plus.net
dalehurlin
Re: Sites very slow
Hi
I have posted a response to another post (the thread is here http://community.plus.net/forum/index.php/topic,148826.0.html)
I am having the issue that the pages are slow or don't load a first a refresh seems to correct it. Is your issue similar?
rongtw
Fixes: 12
Re: Sites very slow
Have ou tried a reboot of router via its webpage , so it puts you on another gateway ??  http://usertools.plus.net/@gateway/ ;
http://www.plus.net/support/broadband/hardware/
