Sites Take Forever to load
kidjensen
As per the title really, The speedtest.net result is 18Mb up/5Mb down which is nothing special..
The real problem is that sites can take up to 2 minutes to load, and sometimes don't load at all...
Started happening about 2 weeks ago, was fine before that.
Anyone else had this and managed to fix it?
Fixes: 62
Re: Sites Take Forever to load
You will need to provide more information
Which device and if a PC which operating system
Which browser
hillyfields123
If you're using Chrome then it has a window you can bring up to see how long resources are taking to load on the page.
You could also try changing your DNS servers to see if they're causing the problem.
rongtw
Fixes: 12
or you can try run Ccleaner & Malwarebytes First  Wink
I'd also try rebooting the router (not the BT modem), this has been known to help on occasion.
Call me 'w23'
MattyC
Champion
Fixes: 46
The community have beat us to this one. All suggestions above are good. Let me know if nothing changes after this.
hillyfields123
We'll end up putting you out of a job soon eh?  Cheesy
MattyC
Champion
Fixes: 46
Don't worry, you've given me work to do as well  Grin
Quote from: hillyfields123
Either way, this sounds like something the CRT should be able to sort out - I know Matty is a provisioning specialist, he sorted me out when we switched!
kidjensen
Info as requested:-
Which device and if a PC which operating system: Win 7 PC
Which browser: Firefox, but the same with Opera and IE
I have run CC cleaner and done an antivirus scan
I have also reset mt router and Fibre Modem several tines.
Loading delay varies from 10 seconds to infinity, but is usually about 2 minutes.
How do I try another DNS?
rongtw
Fixes: 12
sounds like your browser is the problem not the router , which Firefox add ons are you using ?? , have you loads of toolbars ? .
there are some very good guys here who are more technical than me  Smiley
PS is it WIFI or wired connection
kidjensen
It's a wired connection to the router. The problem occurs with different browsers on different User accounts.
A couple of weeks ago it was fine, now it's very frustrating to use...
My gut-feel is that I have a virus that the normal antivirus programs are missing.. I have scanned with a couple of Spyware programs, but no improvement.
rongtw
Fixes: 12
Personally i would use Malwarebytes  https://www.malwarebytes.org/ ; the free one  Wink
but also try to boot it safe mode F8 as PC starts then run Malwarebytes .
you could also type MSCONFIG in the search in start button , have a look at what is in startup tab and unclick the ones that dont look right .
smh
I hope no one minds me linking back again to this thread  from December:
Web pages stall when loading | Community Site
Your problem seems to be the same one which is repeatedly cropping up in the forum, I think three separate threads since then and probably earlier threads.
If the OP's description in this link is similar to your own experience, it's possibly worth a read.  Changing the DNS settings resolved the problem for me in this instance, and as you say, when unresolved it is very frustrating.
You should be able to alter DNS settings either on your computer, or on your router, or both - the examples in the thread were with iMacs but Plusnet also has this advisory page: Changing DNS Settings in Windows XP
