Single website times out on my connection only
davenportcake
Odd one this... As of yesterday, my design business website http://www.swashandfold.com (which obviously I need to access) is inaccessible via my home connection. However the site is up (http://www.isup.me/http://www.swashandfold.com/), working fine for other people, and accessible over mobile data connection. Just not for me via any machine connected to my Plusnet fibre.  Undecided
I get "timed-out" errors (or the platform equivalent) whether I try Chrome, Firefox, my Win 10 machine, my OSX machine, FTP clients or pinging the server.
I've tried the following:
  • Google DNS and OpenDNS (on my machine)
  • Google DNS and OpenDNS telnetted and changed on my router (Technicolor TG582n)
  • Checked any Firewall settings locally, on my account settings, and on my web host (UK2)
  • Checked for any IP blocking on my web host
... and I'm kind of out of ideas now. Its very strange. In actual fact, I don't think its a DNS issue since ping resolves it ok. But its the actual server (109.123.71.220) which isn't playing ball over Plusnet.
I'm not ruling out UK2 of course - there could be something going on their side. But trying to rule out all options.
Any thoughts?
Andrue
Re: Single website times out on my connection only
Based on what you've posted this is a bit left-field but have you always been using Google DNS and is all of the site hosted remotely from your LAN? I ask because some routers like mine use DNS to provide(*) NAT loopback facilities. In that situation if you change to Google DNS it will prevent you accessing anything that you host yourself.
( https://en.wikipedia.org/wiki/Network_address_translation#NAT_loopback )
(*)'Fake' may be a better term for it  Sad
pwatson
The OP's domain is hosted by UK2 - Nothing to do with NAT loopback...
Can you post the result of a traceroute to the domain?
Fixes: 10
Can you access http://cpanel36.uk2.net? (you should get a sorry page)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Den1
Have you checked to see if your IP has been blacklisted by your host's server, it can happen  Wink
davenportcake
Quote from: Den1
Thanks for input all... yep, as Den1 suspected (and I'd been leaning towards myself), it seems to have been down to a particularly thorough session of multi-device, multi-browser responsive CSS development.
It seems UK2 considers synchronised browsing using Adobe Edge Inspect as the equivalent of a Wordpress attack, so decided to block my Public IP. Cheers UK2!
Anyway, thanks again for suggestions!
