Silly speeds today
Fixes: 20
Silly speeds today
Getting ~17Mb
BT
Down 8.7Mb
Up 13.21
Ping 47ms
Switched g/w's and got same.
BT further test:
Download speedachieved during the test was - 8.7 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-61.82 Mbps .
Additional Information:
IP Profile for your line is - 61.82 Mbps
Essexlad
Re: Silly speeds today
Can't throw any light on your problem, but we also had silly speeds on Sunday - down to about 14down & 4up
Andrue
It's not network-wide as mine is fine:
Must be something specific to you. I'm on ptw-ag0.
Fixes: 20
I rebooted the router and it is back to normal now.
