Significant speed decrease for both upload and download - well below minimum guaranteed
- Significant speed decrease for both upload and dow...
- « Previous
- 1
- 2
- Next »
Re: Significant speed decrease for both upload and download - well below minimum guaranteed
10-09-2018 12:45 PM
Hi @caseyw1988
I have ran some checks on your line for you, and it's showing an external fault on the phone line at the minute. I have raised this back to Openreach for you, and they will get someone out externally for you withing 48 hours. If you don't see an improvement by Wednesday evening, please let us know.
16-09-2018 11:57 AM
17-09-2018 12:09 PM - edited 17-09-2018 12:09 PM
Sorry to hear this.
Our tests aren't showing a external issue at this moment in time and the line is testing fine as shown below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 73.9 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 261.7 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-74M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-09-04T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 74.0 Mbps | 74.0 Mbps | 74.0 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 477.0 Sec | 900.0 Sec | 899.2 Sec |
Retrains | 0.0 | 4.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-09-17T10:37:32Z | 2018-09-17T10:52:32Z |
Ingress Code Violation | 2 | 1 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Is the PS4 connected over a wired or wireless connection?
17-09-2018 2:18 PM
@MatthewWheeler Although the speeds are pretty good I don't think that @caseyw1988 should be banded at 74Mbps on a line length of only around 260 metres. My line is about 350 metres and I get full sync speed.
17-09-2018 6:27 PM
17-09-2018 6:34 PM
18-09-2018 12:45 PM
I've updated your fault ticket Here regarding this.
If you can reply to it with the requested info giving us a nudge over here when you've done so we'll be happy to book the appointment in for you.
16-10-2018 7:41 PM
16-10-2018 8:06 PM
17-10-2018 1:12 PM
Hi @caseyw1988
No external fault is showing upon fresh WLR3 testing - which is a good sign!
A GEA test shows that your router is syncing at roughly 74Mbps, which is above the guaranteed line speed you mentioned.
If you are not seeing the "correct" speeds even on this banding, then there is most likely a reason for this separate to the profile issue. As @MatthewWheeler mentioned, can you tell us if your device is connecting via WiFi or through a physical Ethernet Cable?
The fault ticket which @Gandalf opened has, unfortunately, auto closed as it has been open for over 14 days. This can be raised again if you wish/is needed.
Now, there is a potential chance that if we sent off for this banding to be looked at by our suppliers that you sync speed may increase by a few meg, however, this is not a guarantee (it's not even a guarantee that they would do it as the Sync Speed is within their estimates & above the MGALS).
Having said this, I am more than happy to request them to do this - I just wish to make you aware that here is a chance it may not make any difference/be accepted. I've sent this off and opened this ticket on your account with the request reference. The request should be received and actioned overnight.
There will be no engineer visit to your premise required to do this.
Please do let us know if this helps.
MoR
17-10-2018 1:17 PM
17-10-2018 4:38 PM
Hi @caseyw1988
Thanks for coming back to us.
I appreciate your frustration, but if there is an intermittent issue causing the speed/connection problems you've described, it is unfortunately going to follow the pattern you've alluded to. Given the nature of the technology we're dealing with, we can really only address a problem if it's apparent when we test your line.
By all means, we can send out an engineer without a fault being "present" but this does run the risk of you being charged if the engineer finds no fault.
My advice at this stage would be to allow the reset that MoR has requested to take place and then test the speed/connectivity via a wired connection for as extended a period of time as you can manage without major inconvenience. Once we understand how the line is performing under those conditions, we'll be in a better situation to advise on the most useful next steps.
Best wishes
Dave
05-02-2019 9:54 AM
It's now been a few months since this issue arose and it has continued to be a pain but I have managed to get by, but now I've had enough of never consistently being able to sustain a ping rate when gaming and I spend more time under my guaranteed min line speed than over it. I have bad line noise, nothing has changed in my house or the lines to my house. Again, and I re iterate this, it was perfect when I was with BT before I switched. Ever since I switched I have had this problem. Please help! Send an engineer if needed this week. See attached pics of speed tests merely mins apart. The speeds are way apart and so is the ping!
05-02-2019 1:51 PM
Hi @caseyw1988, I'm really sorry that you are experiencing issues. I've tested the line today which hasn't detected any issues and shows you to be in sync at 73.9mb.
I can see you have in the past advised that the issue affects both wired and wireless devices, is this still the case?
If so, and you have ran through our troubleshooting guides and connected your router to the test socket, then please raise a fault here. Please let us know once done so.
- « Previous
- 1
- 2
- Next »
