Significant Wiring Changes - Profile Reset?
- Significant Wiring Changes - Profile Reset?
- « Previous
- 1
- 2
- Next »
Re: Significant Wiring Changes - Profile Reset?
25-11-2020 1:44 PM
25-11-2020 2:24 PM
@iancun, I'm just popping through for you now. I'll pop an update on the support ticket for you once it's confirmed.
Thanks.
28-11-2020 4:53 PM
Not sure what it happening here, the plusnet line rate dropped back to 5mbps in the control panel and sure enough, my internet is back at 5mbps slow speeds - despite sync rate rising to 22mbps.
28-11-2020 5:25 PM - edited 28-11-2020 5:26 PM
Sounds like the DLM reset has somehow reverted the Plusnet profile !!! I don't see why it would though...
28-11-2020 5:26 PM
I'm not even sure the DLM reset has gone through yet, given the stats:
VDSL Training Status: Showtime
Mode: VDSL2 Annex B
VDSL Profile: Profile 17a
G.Vector: Enable
Traffic Type: PTM Mode
Link Uptime: 0 day: 0 hour: 3 minutes
VDSL Port Details Upstream Downstream
Line Rate: 5.411 Mbps 22.399 Mbps
Actual Net Data Rate: 5.383 Mbps 22.400 Mbps
Trellis Coding: ON ON
SNR Margin: 6.2 dB 9.4 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 7.1 dBm 10.1 dBm
Receive Power: -10.2 dBm -17.5 dBm
Actual INP: 0.0 symbols 57.0 symbols
Total Attenuation: 0.0 dB 27.1 dB
Attainable Net Data Rate: 5.383 Mbps 26.894 Mbps
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 10.7 55.4 N/A N/A N/A 24.3 68.5 N/A
Signal Attenuation(dB): 10.7 54.5 N/A N/A N/A 26.4 68.5 N/A
SNR Margin(dB): 6.7 6.1 N/A N/A N/A 9.4 9.5 N/A
TX Power(dBm): 0.4 6.1 N/A N/A N/A 8.8 3.9 N/A
28-11-2020 6:48 PM
Yes, that downstream snr looks a bit like its still banded
28-11-2020 6:59 PM
Thanks for getting back to us @iancun
I suspect the DLM reset was carried out at about the same time we got a profile update this afternoon. I've poked the profile to 21mbps in line with the line speed so you'll no longer be restricted once you reboot your router.
Upon further investigation though, line tests are showing a fault on BT's equipment at the exchange which may be the underlying cause for the banding. I've raised this to our suppliers and we've been provided an estimated response time of by 02/12/20 17:00:00 for an engineer to go out and investigate further.
We'll provide an update as soon as we know more.
28-11-2020 7:15 PM
Thanks @Gandalf, I'll await further details on this once the fault has been checked. Will I need to contact Plusnet every time I appear to be stuck far below my sync speeds, or should this sort the issue out?
I've rebooted the router and speeds are improved again. Hopefully once the equipment fault has been found the banding will be resolved and I can sync at an improved speed.
28-11-2020 7:30 PM
Thanks for getting back to me @iancun
If your sync speeds remain stable, the profile shouldn't ever drop to become a problem of being stuck.
Let us know how it goes over the next few days
02-12-2020 11:03 AM - edited 02-12-2020 11:17 AM
Thanks for your work on this @Gandalf. I woke up to a sync speed of 6.667 Mbps which was a little odd, so I restarted my modem and I'm now syncing at the full 27.706 Mbps. It looks like it has been unbanded now :).
However, the plusnet profile is still set at the 21mbps speed that you nudged me up to, are you able to increase this to make the most of the improved sync please?
Out of interest, did the engineers find anything (if that work has been carried out yet, could just be a co-incidence).
05-12-2020 12:43 PM
- « Previous
- 1
- 2
- Next »
