Signal dropping out
- Signal dropping out
Signal dropping out
24-10-2018 7:18 PM
Hi, I've had an engineer checking out the problem, I now have a new router but it still keeps dropping out, where do I go from here ?
Re: Signal dropping out
24-10-2018 7:59 PM
24-10-2018 8:33 PM
25-10-2018 10:54 AM - edited 25-10-2018 10:55 AM
Hi @Shebabe,
I'm sorry that your connection is still dropping following the engineer visit and the new router. I can see from your connection log that it's still dropping frequently:
However, testing your line from here isn't picking up the cause of this.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 50.8 Mbps | ||||
Upstream Speed | 7.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 811.8 | ||||
Upstream Rate Assessment | Reasonable | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed on Week Days | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 18:00 to 18:15 | ||||
Interference Location | Unknown | ||||
Interference Observed In Days | 3 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 5dB, Retransmission High - 0.128M-20M Upstream, Retransmission High | ||||
Time Stamp | 2018-10-23T10:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 49.2 Mbps | 53.5 Mbps | 51.4 Mbps |
Up Stream Line Rate | 7.2 Mbps | 8.5 Mbps | 7.6 Mbps |
Up Time | 519.0 Sec | 900.0 Sec | 891.6 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-10-25T09:15:57Z | 2018-10-25T09:30:57Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 222 | 95 |
Errored Seconds | 63 | 25 |
Severely Errored Seconds | 40 | 10 |
Unavailable Seconds | 0 | 0 |
The previous engineer thought that the router was the cause of the drops. As the new router hasn't resolved the issue, we'll need to arrange another engineer visit so that this may be investigated further. Please can you add your availability for another engineer visit to the ticket here? If you get back in touch on here once you've done this, we'll get your appointment booked in for the earliest available suitable slot.
25-10-2018 1:26 PM
Hi, I have added new engineer dates, thank you.
25-10-2018 4:05 PM
