Short Range Router
jim13
Short Range Router
After months of frustration , suffering multiple signal drops every day, the solution - as so often happens - appears to be quite simple. My wi-fi signal doesn't work unless my PC is in direct line of sight of, and no more than ten metres from the router.
Next room? That's a no-no.
I'll arrange for Santa to bring a proper router at Christmas and ceremonially bury my Plusnet Hub One in the Council skip.
Sigh....
5 REPLIES 5
Fixes: 1,600
Re: Short Range Router
Sorry to hear you're having issues with the wireless signal of your router.
Can you try the steps Here letting us know how it goes?
jim13
This fix would appear to be for IOS systems. I don't have Apple gear.
Fixes: 1,600
I'd ignore that bit, the steps are still useful for you to split the 2.4GHz frequency apart from the 5GHz one.
jim13
Can't make any adjustments as unable to connect to the page. Cheesed off. Router will be binned.
Fixes: 1,600
Sorry to hear that. I'd recommend making the adjustments when on a wired connection.
