Severely reduced upload speed
scottnkatty
For the past few days my fibre upload speed has dropped from the usual 20Mb to just over 1Mb. Can someone explain how I get this sorted? Download speeds seem fine. Many thanks.
<a href="http://www.speedtest.net/my-result/4162022817"><img src="http://www.speedtest.net/result/4162022817.png" /></a>
sjptd
Re: Severely reduced upload speed
Only very basic suggestions I am afraid:
Try turning the router off and on again.  (NOT the modem)
Try other speedtest sites, especially http://www.thinkbroadband.com/speedtest.html ;   Speedtests do vary a lot, particularly on upload for some reason, and I have found that the most reliable.
The BT tester and profile probably won't be especially helpful as upload profile is always 20Mbps.  Worth a try just in case something peculiar has gone wrong.  http://speedtest.btwholesale.com/ and Further Diagnostics.
I assume this is running wired?
Try (temporarily) turning off firewall and anti-virus.
Fixes: 231
Our testing isn't showing any issues.
I'd recommend following the steps sjptd advised you on.
If your still having issues let us know
 Matthew Wheeler
