Setting Up VDSL Router instead of Plus.net Supplied Router
- Setting Up VDSL Router instead of Plus.net Supplie...
18-11-2016 11:23 AM
Hello,
I am trying to get a DrayTek VigorNIC 132 working but the line state flicks between TRAIN and READY, but mainly on TRAIN. My plus.net supplied router works fine.
Question when you disable the auto setup how long should I wait before trying the Draytek?
I am using the same setting I have seen on other posts like VLAN 101 priority 0, etc.
Does anyone have some tips for trying to get other VDSL routers working with plus.net?
Many thanks in advance.
Regards
Paul
Re: Setting Up VDSL Router instead of Plus.net Supplied Router
18-11-2016 12:06 PM - edited 18-11-2016 12:08 PM
I never bother with auto setup as I don't trust it. To be on the safe side as with all FTTC services do not disconnect and re-connect more than once every fifteen minutes. Login/out is fine but the modem should not be allowed to drop the connection more than once every fifteen minutes.
18-11-2016 4:15 PM
Have you checked your username and password are correct ?
24-11-2016 9:53 AM
Thank you for the information. I will have another go this weekend to see if I can get my new setup working.
24-11-2016 10:06 AM
For curiosity is this an internal card rather than a external unit ?
02-12-2016 11:25 AM
Yes, its an internal PCI Express card I am building into a Linux router I am building. That I intend to install with various software like OpenNMS, SysLog and OpenVPN, etc.
27-06-2017 7:09 PM
Paul, did you ever have any joy with this? I am thinking of replacing the plusnet supplier modem and router with this exact draytek card so I can use my linux server as a router - almost exactly what you tried in this thread. Did the connection ever calm down?
(Also any other advice on how to configure the card would be much appreciated!)
